0 Members and 7 Guests are viewing this topic. Read 1213878 times.
hi zygadryou can vastly improve the sound of your panels with a very light coating of pva but it has to be done in a certain way.I mentioned this some years back on this forum but no one seems to have given it much thought,I have an old 40 cm vh xps testpanel in my loft ,I could get it down and test it for you,or do you have any scrap panels you can test yourself and compair with the untreated panels ,the test panel does not have to be the same size as the db output and sound will be very similar above say at least 200HZ if a 40cm panel is used if my memory serves me well.using any poly panel or foam panel without a light coating will have a lot of self noise will tend to be over bright and have a tendency to sound hard at times,vh xps is no exception.Steve
GIANT KILLER PANELS PART TWO. (in the music room ,no one can hear you scream…………….with joy!)Since building the first 18 inch wide panel with one exciter, I have made two further panels, one 2ft and one 4ft wide, all 4ft high and 25mm thick, using two exciters per panel.The t-amp I was using is rated at 8 watts at 8 ohms, if that.This drove my hifi News test cd with the sound of BIG BEN striking twelve, to realistic levels,I kid you not! Plus the lovely sound of the clockworks clinking and clonking as clear as a bell…..ha ha . I am sure the neighbours loved it as much as I did.So I think I can safely say that these panels are very, very efficient.To make these panels is very easy, and only takes an hour or two If using a hair-dryer,but the hf will not be good until the glue hardens, this takes at least 24 hours, so be patient.You could do as I do ,and just hang them from a stand ( cheap up lighters, in my case -best sound for me so far), but if you mount the panel in any other way you must make sure you do not restrict the panel movement in any way, or else you will lose dbs and alter fr. So take care.The glue I have used for the panels is nothing special. It is just that I had a gallon lying around and it sounded good on other panels as damping.The 2ft by 4ft is probably the easiest size to work on and you can easily cut an 8ft by 4ft sheet into four to fit in the car,if using a van or lorry 8ft by 4ft max !!!I would love to try this and could use it as a projector screen with a higher quality polystyrene. The panels do not shake around as my metal panels used to - its just a thought,so far! To damp the panels I used a 50 50 mix of water and pva mixed in a 1 lb (400grm or so?) jam-jar ,this should do 2 panels, a thin a coating as possible so the panel is just wetted, if you use too much glue you could over damp the panel but if it is still under damped you can add another thin coat. If you are doing this on the kitchen table be warned glue will seep through in places .The panels should be damped on one side only!!! And this is the side the exciters will be glued on, you can use a hair dryer to dry this coat, 15 mins or so, and when dry, its time to glue the exciters on.I used undiluted pva for the exciters, using a match-stick to apply the glue onto the foot. Try to get a nice mound of glue on the base and also dab the sides of the foot. Make sure none goes into the voice coil.Just remembered that I used sand-paper to take the shine off the exciter foot and hopefully give a little adhesion.I also applied a thin coating of undiluted glue about 3 inches in diameter around the fixing position. Not sure if this helped in any way but that’s what I did.Also using the match-stick, build up a small mound of undiluted glue around the area that the foot will come into contact with the panel. The glue will shrink and hopefully this will help fill the gaps.You could use the hair-dryer to start the drying process on the panel and the exciter, before sticking them together.Using glue that does not shrink, so as to fill in the gaps could be an idea at a later date but the sound would have to be checked.I also placed a little bit of weight on the exciter to give a good bond, enough to push the exciter foot into the panel without damaging the voice coil.Dry the glue using a hair-dryer, waving it around from all sides. The exciter will eventually get hot ,very hot, but don’t worry.. If you are a little worried that the panel is getting too hot, you could always leave it to dry over night instead, its just that I only had a couple of hours till dinner and my wife had a gun at my head!So if you have to move them after a couple of hours keep them somewhere with a flat surface and leave them to dry overnight ,you can wire them up ready but they will not sound good until the glue hardens, probably after a day or two.If you are using two exciters I found it better to have the connections facing each other (on the inside) but it’s your choice.While I think about it I hope every one has removed the horrible plastic casing with those stick on wobbly feet, if not you have got problems!AS for the position of the exciters ,I used a one third up from the bottom and a one third down from the top in a centre line, other spacing’s could give a better sound ,or maybe not.But this position sounded superb so it’s a good start.Also I rounded off the corners of an experimental panel which I had used to trial the damping But can’t say that I heard a lot of difference, my mind was on other things at the time and now they are lying on the chair with the exciters ripped off but hopefully I can try again at a later date. sedge
thanks jeffacpatent -pending ,that sounds fun,not as much fun as nailing my head to a table for years I have coated my panels with pva, but in the last year I have changed the method, which has altered my understanding of the panel
