0 Members and 9 Guests are viewing this topic. Read 1215953 times.
You CAN NOT use high powered amplifiers with these exciters and crank up the volume...........they will get hot and fry and/or detach from the panels. This has happened to me so I know.I have gone back to my horn speakers for some time now and do not listen to the panels anymore.That does not mean that I have trashed the idea, it's just that until a true ''HIGH POWER''/''HIGH EFFICIENCY'' exciter is made, there is no point in continuing to try to get real volumes out of them.............they just can't do it.
ear some "holes"in some frequencys, next to experiment.
Thanks Tino.I was thinking in a dsp equalisation. I have a MiniDSP system to assemble and test. I believe that it will help a lot for this panels. What do you think?
About clipping, only when is really loud in my case, and the volume is so high that i cannot enjoy the music. I am using a tripath based amplifier, digital of 150 Watts per channel and it works fantastic.
I have some pictures of my panels, i will post them later.
Dont know if better. I had the HiWave from PE and they had same quality reproduction in my panels. But, the Visaton have the possibility to bolt them.
On the images. I added some weight with lead on the exciters. Attached to the panels with velcro to support them vertically . The velcro do not transmit vibrations to the panel and vice versa. Added some damping on panels to test. Not sure of the results yet, need more test.
