0 Members and 9 Guests are viewing this topic. Read 1215972 times.
The way I see it is that we MUST mount the above exciter (no choice anyway due to its very heavy weight)to a back spline or supporting brace and then attach the panel to the array of exciter feet. This way there will be no added mass to the panel and the exciter's voice coil will not be under strain providing the panel is supported in a frame of some sort.
so, I don't know if any of you is listening some metal.this kind of music has a problem: compression.f.e:http://i43.servimg.com/u/f43/17/03/84/13/clip_a10.pngthis "thing" causes NXT to clipping sometimes.does anybody had have the same problem?
Interesting. Is this plastic or??? I would like to know how heavy it is?
