OTOH, a clean enough sub with proper directivity to match the panel is the difficult portion, I guess...
.... It is not a self made exciter. ....
Is the only advantage of using multiple exciters for SPL?I only have a small room, around 8-9ft square-...Would one be suitable for lower volumes (I was using the Omnes Audio BB3.AL (Veravox 3) in OB, and was getting enough overall SPL from that (no bass though to be expected.)
Here is a picture of my modified exciter.You could hardly belive it, but it sounds great Kludden
.... I took an 3 inch fullrange speaker, cut off the membran and glued a piece of tube wood to the spool, instead of the membran. ....
