Hey UK people, if you got your VH grade EPS panels, where did you get them? Can't seem to track it down that easily in 10-12mm format, just fat 25mm for construction industry or small expensive bits for model making.Cheers,V
Is the panel suspended? If so how high from the floor? Do you have a picture? Does the stereo image have depth? With your single stereo panel can you describe what you hear vs 2 panels in terns of sound stage and stereo image? I would suppose that your arrangement is more coherent. It seems to me that it's interaction with the room would be most important. Can you tell us more about the placement of your panel? If I understand correctly you use 8 exciters, 4 right,4left?
POL,Interesting post, as always. CC = corrugated cardboard, right? Do you use this as one large flat piece, or is it folded slightly, like say a tri-fold, into thirds with the end pieces folded slightly in or out? Do you think that three similar-sized panels each one one-third the size of your one panel and wired the same way as you have done would work as well, or is there something about having all the exciters on one single panel that makes a difference? Have you tried the material ZYGADR uses?Interesting, interesting.Bobloblob
So guys , what about Rohacell ? Yours opinion ?!
Rohacell price only 1,4Euro/m2
