0 Members and 7 Guests are viewing this topic. Read 1213831 times.
I'm afraid that balsa is not the wood of choice.
I had to order 16 2'x4'x 1/2" panels to meet the minimum order
Where are you located? I may be interested in buying part of that order from you...I just looked at your profile, I bet you are on the other side of the pond... John
I have a small subwoofer for my computer under construction and because it´s so little I´d like to substitute the bass-reflex tube with something else on the back side (similar to "passive radiator"). Maybe a piece of EPS??
