Tube Damper Questions
0 Members and 1 Guest are viewing this topic. Read 4099 times.
Eric
« on: 28 Jul 2009, 08:28 pm »
I have the SAS 11A and the Monarchy SE-250 Monos. Bot use 6922 type tubes (I am currently running 7308=E188CC in all of them). Which dampers would y'all recommend?
some young guy
Re: Tube Damper Questions
« Reply #1 on: 28 Jul 2009, 08:58 pm »
Personally, I like the Peek Halo-9s and as luck has it: they're on sale for $12.49 each.  :thumb:
Herbie
    • Herbie's Audio Lab
« Reply #2 on: 28 Jul 2009, 09:10 pm »
Hi, Eric. All of Herbie's Vacuum Tube Damping Instruments work very well with 6922-type tubes. Although differences between them are subtle, descriptions on our website are straightforward, to help differentiate.
To bring out the best potential of your gear, I recommend Preamp UltraSonic or UltraSonic Rx. Preamp UltraSonic will unmask lots of intricate detail, while Rx adds a highly resolving yet slightly more "organic" result. You wouldn't go wrong with either.
A combination might yield ideal results for you: UltraSonics in the preamp, Rx at the monos (or PEEK at the monos if you'd like to bring out a little more "heft" in the mids/lower-mids.)
Steve Herbelin
Herbie's Audio Lab
« Last Edit: 24 May 2011, 10:27 pm by Herbie »
Eric
« Reply #3 on: 29 Jul 2009, 02:37 pm »
Thanks for the recommendations. What is PEEK?
Eric
« Reply #4 on: 29 Jul 2009, 02:39 pm »
Nevermind, I found them. I am going to order today
Eric
« Reply #5 on: 29 Jul 2009, 04:38 pm »
Just placed my order. Also ordered some for my Modwright 3910 (6900 dupes and the rectifier tube in the PS)
