What DAC are you running with your Salk speakers?
0 Members and 1 Guest are viewing this topic. Read 45383 times.
Hydro
Re: What DAC are you running with your Salk speakers?
« Reply #120 on: 27 May 2021, 05:25 pm »
Audio Note Kits Level 4 and Level 5 with Duelund coupling capacitors. These are single bit converters based on the 1865 chip with transformer inerstage coupling and c core output transformers. The only problem is that they only decode up to 48khz, no high rez. They sound better than my other dac's that decode up to 192, so it really isn't a problem. I would say that they sound analog but they sound better than my SOTA turntable combo. The kits are easy to build and easy to upgrade.
sletnty
« Reply #121 on: 15 Jun 2021, 08:26 am »
Weiss DAC202, I have used for many years and have zero complaint.
bkatbamna
« Reply #122 on: 20 Jun 2021, 12:04 am »
Running a Zerozone tube preamp for CD, turntable.  Using Emotive Basx t100 for streaming and computer.  Hooked to a Yamaha B4 amp driving Salk V3 speakers
Matt123
« Reply #123 on: 1 Jul 2021, 09:58 pm »
I have Salk Song towers and am using a Schiit Bifrost Multibit.
SCompRacer
« Reply #124 on: 12 Sep 2021, 05:12 pm »
I've had Twisted Pear Buffalo III 9018 dual mono and 9028 builds with my SS8's.  Now a single BIII 9038. Twisted Pear Mercury fully balanced active I/V line stage. Amanero USB-Hermes-Cronus Combo input (provides isolation, reclocking). Went simple, no Arduino control this time.
Gyosa
« Reply #125 on: 30 Sep 2021, 01:43 am »
Cambridge Audio 851n
PSAudio S300
Supercharged SongTowers
Bk
GlennDog
« Reply #126 on: 3 Oct 2021, 08:41 pm »
That looks sweet, Rich . . . I wish I had the skill-set
Rock On, brother!
mr_bill
« Reply #127 on: 3 Oct 2021, 10:43 pm »
PSAudio S300
Bk
How do you like your PS Audio S300?
Gyosa
« Reply #128 on: 11 Oct 2021, 09:31 pm »
Pairs beautifully with the Salks !
Bk
Empoweryou
« Reply #129 on: 16 Oct 2021, 09:35 pm »
I've been quite happy with my Schiit Gungnir MB paired to SC Songtowers.
tofuman
« Reply #130 on: 13 Dec 2021, 09:30 pm »
Aesthetix Romulus Eclipse CDP w/optional volume control & NOS tubes.
CEC Transport & Bricasti M3.
Waiting to try the new Sonnet Pasithea ladder DAC.
« Last Edit: 16 Dec 2021, 05:57 am by tofuman »
