0 Members and 1 Guest are viewing this topic. Read 37770 times.
Anyone know how I can use the Onix A120MkII as straight amp/ht bypass mode? It seems that the right channel on my Acurus A250 is not working correctly (getting a loud hum) and would like to use the A120 with the Response Audio Pre, while I look for a new amp. The A120 does have a tape in and out connections on the back. Can I use that, if yes any direction/guidance on how to do that?Thanks
I found the source of the loud hum that I was getting on the Acurus A250. It turned out to be the APC Surge Protector that I was using. Switched it out for something that I had picked up from Loews and no hum.
Fresh off the press.Read the professional review of our XIA-160 Int. Amp. & XCD-50 Reference Player.http://stereomojo.com/
When are you guys going to start your own manufacturers circle? There's a bunch of Onix reps posting here now, and it would be nice to see your product information in one place.
How do we do that?I thought there's a requirement for a vote?
I believe everything you need is right here:http://www.audiocircle.com/index.php?topic=71779.0
