Other Stuff
Archived Manufacturer Circles
DIY Cable
Passive Radiator Packages
0 Members and 1 Guest are viewing this topic. Read 1860 times.
Kevin Haskins
24 Jul 2009, 07:30 pm »
I'm offering these Passive Radiator packages at a huge discount. Essentially, your getting the passives at cost when you buy a driver.
I've documented the build completely so the beginning DIYer can easily build them, or if you don't have any desire to build a sub, you can take the plans to the local cabinet shop and have a custom subwoofer made to match your decor.
http://www.diycable.com/main/pdf/Shiva-PR.pdf
http://www.diycable.com/main/pdf/Shiva-PR-Drawing.pdf
Prices are as follows:
$235 Shiva-X + PR-15 necessary mass, & mounting screws.
$295 Shiva-X + x2 PR-15 necessary mass & mounting screws.
Just add one of the PE 500W amps and you have a fantastic little package.
You can find them here:
http://www.diycable.com/main/product_info.php?cPath=24_93_153&products_id=691
Last Edit: 27 Jul 2009, 01:20 pm by Kevin Haskins
persisting1
Re: Passive Radiator Packages
26 Jul 2009, 12:33 am »
The links don't seem to be working.
Or it could just be me
Kevin Haskins
Reply #2 on:
27 Jul 2009, 01:21 pm »
There you go... updated.
Other Stuff
DIY Cable
