0 Members and 1 Guest are viewing this topic. Read 16027 times.
Thanks for the warm welcome everyone! I have some work to do to pass the time. going to add a 20 amp dedicated circuit or 2 and get a rack so everything will be set-up so all I will have to do is plug in the HT2's. Should I hold off doing any room treatments until everything is in place? K Shep, do you have any pics of your treatments? Not sure if I have the time to do any myself but will consider that.
Kirk, you have mail.Great thread link vintagebob and I love the title I will have to hang there some too.I will mosey over to the Acoustics Circle and check that out.Room info: Placements are just preliminary.
Second, also consider experimenting with long wall placement of the HT2's. It works beautifully here with my HT2-TL's in a similar (13x17) sized room. If this setup works well in your room it affords you a much wider sound stage. Think panoramic 16:9 versus 4:3.
