0 Members and 1 Guest are viewing this topic. Read 3253 times.
When I get my sub and ST set up, I'll probly spend quite a bit of time running with and without sub tests to see what I like better. In the end, I'll probly run the sub because it cost me a pretty penny and I'm sure as a rythmik it'll more than keep up, its not just an explosion box
I have a two-channel system, and I don't use a sub. The HT2-TL's F3 is 32hz, which is sufficient for me. How low are you trying to get?
QuoteWhen I get my sub and ST set up, I'll probly spend quite a bit of time running with and without sub tests to see what I like better. In the end, I'll probly run the sub because it cost me a pretty penny and I'm sure as a rythmik it'll more than keep up, its not just an explosion boxWhen you test the SongTowers with the sub, try the Songs as a small speaker. I found that helps clean up the midrange even more to keep the base signals off the midrange.Bob
jazzcat - Enjoy those HT2 TL's! I look forward to reading your impressions and seeing some pics when they arrive. Which veneer are you going with?
