0 Members and 1 Guest are viewing this topic. Read 4923 times.
Looks good but I am a little confused. I am not quite sure I understand the digilog bridge. I would expect with the external digital crossover you would require 4 channels of amplification?
Looks good but I am a little confused. I am not quite sure I understand the digilog bridge. I would expect with the external digital crossover you would require 4 channels of amplification?just curious.
It can however be ordered with 3 pair of binding posts to do the 3 way.Brian felt that many might find "biamping" more easily perfromed than "triamping".
Total MSRP is $2496 plus shipping.
Jut to be sure I understand. In this package the Dared would run the top end and you would be using your own amp for the bottom? I didn't understand if the Dared was supposed to be able to run the whole set up, and I am guessing that it can't but just wanted to understand.
BTW John, how would this be as a stimulus package? I would think that a pair of 626jr's or better yet RM-30's, biamped with a Nu-Force or Bryston amp on the bottom and one of Dared's 300B tube amps on the top would sound like a MILLION BUCKS! Paul
The Dared is a 6 channel amp! I understand now, sorry for not paying attention. Just to cause trouble though then two channel would go unused because the SDE is only 4 channel, and perhaps with a mono sub output? so, two channels go to the neo panels and tweeter (via the digilogue crossover) and two channels go to the woofers.
I seem to recall from another thread that the DQX will only output 4 channels, or am I wrong on that a well?
Seems to be my day (or two) for being wrong.I have just moved into a smaller room and am exploring options. Much as I would really like a set of RM30 I think my room is just too small. A 626 package with the DQX might be just the ticket. I have a AVA U70 that I would use for the panel and tweeters and a Pass aleph 30 for the woofers (probably not enough power, but just maybe as I don't really crank it up) I would plan on crossing that over using my Pioneer VX59i receiver's crossover at 80 hz to a pair of VMPS smaller subs.that would do it, right?thanks!
Well then, that muddies the waters for me. I had thought to avoid the RM30 because I would have trouble integrating the woofers of the RM30 with my pair of smaller VMPS subs. If I can run the RM30 as full range as follows:Tweeter and neo panels: AVA U70Midrange: Pass Aleph 30Woofers: 250 watt sony ampUsing all six channels of the DQXThen use the crossover in my receiver to support the subs, run the RM30 full range.Does this work?So I am back to the same question, 626 or RM30?Still have a bit of time to think about it.
