What happened to internet radio via Squeezebox?
0 Members and 1 Guest are viewing this topic. Read 6792 times.
WGH
Re: What happened to internet radio via Squeezebox?
« Reply #20 on: 11 Jul 2009, 08:47 pm »
That is good news, sometimes it is easier just to uninstall then re-install than trying to troubleshoot.
Wayne
JEaton
« Reply #21 on: 11 Jul 2009, 09:54 pm »
SqueezeCenter doesn't use the Windows registry.  Settings are kept within text files.
The problem sounds like it could be a transient DNS issue, where the server is unable to resolve the squeezenetwork.com.  SqueezeNetwork also seems to have had a lot of issues lately.  I think that much of the time, SqueezeNetwork just goes down completely for short periods.
http://forums.slimdevices.com/forumdisplay.php?f=10
WGH
« Reply #22 on: 12 Jul 2009, 12:40 am »
Some settings may be in text files but Squeezecenter does use the registry too.
Wayne
JEaton
« Reply #23 on: 12 Jul 2009, 02:15 am »
None of those entries are SqueezeCenter settings.  If you used the Windows installer you'll have those.  It's 1) standard Windows installer stuff so that you can press a button that says "uninstall", and 2) firewall entries created by the installer that open up the ports used by SqueezeCenter.
