What about putting a paper poster over a treatment?
0 Members and 2 Guests are viewing this topic. Read 1437 times.
topher_m
Hi
Would the high freq behave really be affected that much? Clearly thin paper isn't going to do much on midrange and lower.
Basically asking about making a cheapo art panel - use a regular treatment and put a poster on the front rather than a custom printed image on fabric.
Chris
richidoo
Re: What about putting a paper poster over a treatment?
« Reply #1 on: 9 Jul 2009, 05:54 pm »
Paper of poster thickness will reflect highs down to well under 1kHz. Thinner paper might pass lower freqs, but not much. "The midrange" extends to ~3000Hz.  I have made acoustic treatments with brown kraft paper coverings before. I felt that they sounded a tad too forward in the midrange and up. But other experienced audiophiles commented that it was just right. Different taste. I don't know if the forwardness is direct function of the reflectivity, or from the overtones generated when paper membrane vibrates, like in a drumhead. Thin plastic is a much gentler reflector, since it is less resonant than paper, but tough to print a picture on it.  I do like the sound of palette wrap plastic as reflective mask fwiw, it is much thinner and nonresonant. Depends how much midrange your room needs. Mine needs a lot, so the paper wasn't so good. If you room is not too lively in the midrange, then paper could be perfect for you.
GIK Acoustics makes custom dye sublimation prints onto acoustically transparent cloth. But it costs a little bit more than paper. ;)
Ethan Winer
  • Audio expert
« Reply #2 on: 10 Jul 2009, 02:28 pm »
Paper over bass traps is fine, but not on absorber panels at reflection points.
--Ethan
