Cleaning the face plates
0 Members and 1 Guest are viewing this topic. Read 1730 times.
Afterimage
« on: 7 Jul 2009, 12:51 am »
what do you guys suggest I use to clean the face plate on the RWA amps/preamp?  Thanks
Vinnie R.
    • http://www.vinnierossi.com
Re: Cleaning the face plates
« Reply #1 on: 7 Jul 2009, 12:54 am »
Hi Afterimage,
I recommend you use a soft, slightly damp cloth and rub with the grain (horizontally).  Try to use a cloth with low lint.
Best regards,
Vinnie
srb
« Reply #2 on: 7 Jul 2009, 01:32 am »
Microfibre cloths work best for damp water cleaning, and leave no lint.
nonoise
  • A republic, if you can keep it.
« Reply #3 on: 7 Jul 2009, 06:52 am »
I use Goo Gone. Great stuff. Just spray it on a clean, lint free cloth and gently rub. Leaves nothing behind and takes off the tuff stuff. Will not (in my experience) damage any metal surface. Got it at Lowes some years ago.
