0 Members and 1 Guest are viewing this topic. Read 6612 times.
Now, the only issue is will my wife have a stroke when she sees the Corners in the front of the room
shit and then killed me
It's pretty amazing how much some room treatment helps, especially considering the cost. Glad you took the plunge. Maybe some more treatment could make it even better!
Byteme, thanks for perking up my anticipation in receiving my RoomPak. I can't believe that those corners look as bad as you make out. Not that's really an issue with me, I lean toward the Josephson philosophy, it's all about the music, decor be damned! And if this room treatment is all you say it is, I'll be a happy audiophile(in the making). Regards, Robin
Thanks for the review, Brian.Is your improved acoustics due exclusively to the deadening of reflective sounds? Did you do an informal slap echo check before and after installation? How does it compare to when your wife slaps you across the face?
Can you cover these with a material that is acoustically null like a GOM???(Guildford of Maine...701 series????).This might give it a better appeal for room decor and the WAF factor. Just wondering.....Larry
