0 Members and 1 Guest are viewing this topic. Read 56409 times.
SP3 and a music player to go with the BDA-1james
If it`s a music player to partner BDA1 then you`ve got one sold over here!
Hope in about 3 months.james
Wil he contain a harddisk or will it be a streamer ?
Well, I just acquired a Logitech/Slim Devices Transporter... Markus
No harddisc and no streamer no display, no CD player or ripper, no fans
I do get the no harddisc, no display, no CD-Player, no fans part, but where does the music come from then? Does it have an ethernet or USB port? Does it build on a dedicated server/application that does the file handling and sends the files to the digital media player that does some decoding and sends it to an D/A converter via AES/EBU???Markus
Hi Markus,Yes a USB thumb drive (CD of the future) or hard wired Ethernet connection from dedicated music server.james
James, are there any photos of the device?
JamesWhat about a Bryston branded USB drive with a black or silver aluminum body offered through Bryston StuffJust a thought ...Will the new device be the same dimensions as the BDA-1 or smaller
James,1) an idea of pricing for the new player? 2) you said that the player will be connected via digital xlr with the BDA-1. other inputs as well except usb and xlr ?3) and yes, some more Bryston stuff is indeed a good thought! al.
James,Will this device be "slaved" to the DAC (i.e. the DAC's clock is the sole clock in control)? Thinking of jitter reduction. Aaron
