Bryston future products
0 Members and 1 Guest are viewing this topic. Read 56533 times.
Robert D
Re: Bryston future products
« Reply #140 on: 29 Jan 2010, 02:28 am »
James. I guess that means I'll need another BDA-1
or a Split or y AES/EBU connector to connect your New Product.
I maybe the 1st to ask but I'm sure it's possible.
Robert
Robert D
« Reply #141 on: 29 Jan 2010, 02:37 am »
Robert
James, it's that High End Clean Sound I'm looking for That Digital AES/EBU puts out !
Robert
nikon
« Reply #142 on: 29 Jan 2010, 04:07 am »
James
Sample of a metal bodied USB key FYI
'Encased in a potted metal case, not plastic, making it one of the strongest USB keys around
Exceeds MIL-STD-810F military waterproofing standards'
Will the new device dimensions be
Same width and height and depth as the BDA-1 or
Same width and height as the BDA-1 and same depth as the BP-1.5 ...
Phil A
« Reply #143 on: 29 Jan 2010, 04:42 am »
Robert
http://www.sjmediasystem.com/ets-pa830.html
http://www.computercablestore.com/AESEBU_XLR_Digital_Splitt_PID7412.aspx
werd
« Reply #144 on: 29 Jan 2010, 07:13 am »
You win my eternal gratitude.
james
K i will take second prize then....  :wave:
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #145 on: 29 Jan 2010, 09:29 am »
James
Hi nikon,
Trying to do it with same chassis as the BDA-1
james
alexone
« Reply #147 on: 30 Jan 2010, 05:06 pm »
The sound card is in the Bryston Player
james
James,
so what soundcard is used finally?
al.
« Reply #148 on: 30 Jan 2010, 05:12 pm »
James,
al.
Hi Al,
Still playing with that but the one your recommended looks real good.
james
alexone
« Reply #149 on: 30 Jan 2010, 05:55 pm »
Hi Al,
james
James,
good news!
al.
dirk
« Reply #150 on: 31 Jan 2010, 06:59 pm »
Only usb as input ?
Internal ssd harddisk ?
All the rest true the dac, like the apple ipod and other ?
« Reply #151 on: 1 Feb 2010, 12:28 am »
Only usb as input ?
Hi Dirk,
Any USB device - thumbdrive or harddrive. Or Ethernet hard wired connection to dedicated server.
No internal hardrive
james
Phil A
« Reply #152 on: 1 Feb 2010, 01:00 am »
James - how would one select the particular music they wish to play say for example with a USB thumb drive?  Is there a monitor output with a menu or some type of display on the unit with a menu to navigate?
VOLKS
« Reply #153 on: 1 Feb 2010, 01:07 am »
All this Bryston USB device/thumbdrive/ harddrive/ dedicated server/downloads reminds me of LINN announcing to the world the death of the CD and that they are moving on and hearing a LINN rep go on and On about how AMAZING their new Digital Stream Players are and how much LINN feels they are so much better then the CD(isnt this the same company that said the CD would die in the 80"s?) LOL......Although now yes the CD is dying and digital downloads will proably take over.......i dunno ...maybe i am just bitching to much.......but i am feeling depressed that the CD is dying :(.....i am 37 so yes i seen and lived the tail end of main stream LP's dying,but i seen the start and now gradually the end of main stream  CD's....i wish it wasnt so:(....but dang i feel so cold to all this USB-Thumbdrive Hype ....it gives me no warm emotional response and its as exciting to read as watching paint dry(but i keep reading it anyway lol).........i guess maybe i am feeling what some people felt when LP's died out in the main stream?...Am I alone 100% here on this?Can anyone relate?.......Its not just Bryston of course(I love and have their amps/pre and Cd Player)....its most Audiophile brands that seem to be getting into  digital downloads in some way or another.......just wish it wasnt so.....but thats Progress(?) i guess....cheers
« Reply #154 on: 1 Feb 2010, 01:35 am »
You can use an iPod or iTouch (the new iPad looks promising as well) or a Web-brouser on the home network to access and manage your music files.
james
Phil A
« Reply #155 on: 1 Feb 2010, 02:12 am »
james
So does it have more than a single USB?  What formats will it decode or is it just a player that reads whatever format you have connected to it?  I thought I read something about a sound card earlier.
95Dyna
« Reply #156 on: 1 Feb 2010, 08:40 pm »
How about an external step up transformer for those of us who bought the BP26P and want to change from MM to LOMC.  A secondary benefit would be if somebody is buying a new BP26 and has a LOMC cartridge and wants to have the stereo mono/switch on the front panel they can buy the BP26P and the extrnal step-up and everybody's happy. :D
« Reply #157 on: 1 Feb 2010, 09:02 pm »
Hi Phil,
I am thinking 2 USB ports on the back and one on the front.. for when the friend drops over. It will be dedicated to quailty files from 44.1 to !92 Wave, AIFF and FLAC.
james
Phil A
« Reply #158 on: 1 Feb 2010, 09:21 pm »
James, I guess this might be a drop off target and perhaps should be filed in a new thread perhaps dedicated to the music player perhaps when it gets further along, but can we have one with your answer above and any other details.  I'd find it helpful if someone could also point to software to convert files for one (when of course it gets closer to release).  I have lots of things in WMA lossless from CDs.  So I guess I'm asking if we could have a separate thread when it gets closer to release dedicated to the product and then everyone can chime in with helpful hints.
« Reply #159 on: 1 Feb 2010, 10:46 pm »
ABSOLUTELY :thumb:
