0 Members and 1 Guest are viewing this topic. Read 16016 times.
Quote from: Woolz on 19 Jun 2009, 12:39 amtarga02, wonderful, I am glad they have an appreciative home. I always liked to think the maple made them sound special.Hi Woolz, I am not sure whether the maple makes them sound special, but they are certainly a big step up from the Rocket 1000s they replaced! I am driving them with a Wyred ST 250 (125watts/8) currently, but am going to upgrade to the Wyred ST 500 later this month. Rick Cullen is great to work with BTW.Yes he is. Very trustworthy and pragmatic about what he decides to take on.
Jim let me borrow the original prototype pair of Archos speakers Sunday and I'll have some observations of my own soon. Interesting speaker for sure.
I have no bananas, er, tube amps. I have an Electrocompaniet AW220 and a DAC4800A - 70 wpc and 380 wpc. They are very efficient speakers. 6 o'clock is 0 db and I haven't got past 10 o'clock and it's LOUD. Had to do that with Hocus Pocus by Focus - rockin' out! Not the right speaker for that tune.
I think you'll be surprised at what is in my system these days.
I'm not sure what you mean by a dome being more "honest" than a ribbon tweeter. I'm not aware of any information that a ribbon obscures and a dome reveals. It sounds more like a voicing issue than a technology issue.
I like the sound of ribbons a lot, and plan to switch my current home speakers over from the Peerless HDS to the AC G2. The crossover is complete, just need to modify the cabinets. Having said that, tests I've seen show that the MDT33 has extremely low non-linear odd-order distortion , lower than any of the ribbons out there that I have seen tests on. Since non-linear odd order distortion can be audible, there may be a different "flavor" to the tweeter. Of course, directivity is very different too, and this changes how we perceive it as well. However, voicing does certainly have a huge impact on all of this, but I tried very hard to balance the G2 to match the level as closely as possible to what it was with the MDT33. Finally, one more observation: I have found that a dome with a strong low distortion motor seems to carry more dynamic "punch" at the lower end of its operating range compared to ribbons I have used, which may aid in the way it crosses over to a mibass. Ribbons, on the other hand, sound much more open and realistic at the top of their range. This probably correlates to better acoustic impedance matching with the air-load at the lower range for a dome vs. much lighter moving mass for the ribbon at the top. Still, there are many factors involved.Jeff
The only controlled, direct tweeter comparisons I've done with Salk speakers have involved the 0W1 or 0W2 vs. the LCY ribbon. The little Hiquphons no doubt lack the low-end impact of the larger Morel. But in the comparisons I've done, the LCY actually had more low end output than the Hiq's. Still, I believe in measurements, and it's pretty clear that ribbons (other than the super expensive RAAL) don't do as well as domes in odd-order distortion tests at lower frequencies. I think we agree that there are other ribbon attributes that overcome this in the reproduction of very high frequencies, but distortion is never a good thing. It's a tough nut to crack. The obvious answer might seem the use of a very small mid (like a dome) crossed to a ribbon for the highest frequencies. But that's clearly impossible in a 2-way, and in a 3-way with deep bass capabilities, the mid has to be able to get down cleanly to around 300 Hz to work well with a large woofer.
