0 Members and 1 Guest are viewing this topic. Read 32076 times.
you're going to have difficulty wiring 16+ 5ohm units together and producing a speaker with > 1 ohm impedance.
Quote from: virtue on 10 Jul 2009, 02:24 pmyou're going to have difficulty wiring 16+ 5ohm units together and producing a speaker with > 1 ohm impedance. Why? Straight forward series/parallel with 16 drivers will get back 5 ohms.dave
I think you will be right at the limit. Those planars do need a lot of power.The Virtue can drive 2 ohms, and the 130W supply will be needed for the Apogees. But you might still be right at the limit.Can you take your amp to the speaker to try?
They do look similar from the front.But I doubt they sound anything alike. The A3 has a low Fs and large x-max to allow it to play low. And it will play low in a line array. What is given up is effeciency.Your driver is probably 15-20dB more effecient.
Hello "Virtuers"!Many greetings from Austria Oskarp.s.:Thanks to Michael Mardis! When I looked for the "Trends"-modifications on his site, I got aware of Virtue--and ordered the TWO on the same day.
Are these amps okay with a 4 ohm load? Just bought a used V-1.
