itunes in xp
0 Members and 1 Guest are viewing this topic. Read 1562 times.
KingStyles
itunes in xp
« on: 11 Jun 2009, 08:02 am »
Is there a way to get good usb audio with the new version of itunes or do i need to use jriver or foobar? If using jriver media center, how should I set it up for optimal playback.
audioengr
Re: itunes in xp
« Reply #1 on: 12 Jun 2009, 05:43 pm »
I would still not recommend using iTunes with PC, except with WiFi devices such as AirPort Express or Apple TV.
For Jriver, I would recommend XP on a laptop, not a Dell, and unmap the device.  If you must use Vista, this will sound good, by may improve if you use WASAPI.
Steve N.
