As per prior post, I have my speakers reversed for mid and bass. It certainly seems to be working for me but the post didn't seem to spark much interest and I don't think many others have tried it (nor felt the need to).
As per prior post, I have my speakers reversed for mid and bass. It certainly seems to be working for me but the post didn't seem to spark much interest and I don't think many others have tried it (nor felt the need to). If you're tri-wired, as I am, it is extremely easy to try as I'm sure you're aware. If you have a recording that you find sounds thin and 'sucked out', see if reversing the polarity gives you better body and projection. Conversely, if you have a recording that you feel already has those qualities then see if the change is detrimental. I believe some folks who have the benefit of a phase switch in their system will move back and forth for different recordings. I haven't observed any negatives, but the benefits have been more obvious on some recordings than others.Sadly, the folks at Hyperion are not inclined to share their thoughts on the circle here. I don't know if there is any percieved conflict in manufacturers doing so. I would be interested to know if they agreed with the phase reports for the 968 and if they made any changes as a result of that review.
Quote from: watchemglow on 4 Sep 2009, 06:36 amAs per prior post, I have my speakers reversed for mid and bass. It certainly seems to be working for me but the post didn't seem to spark much interest and I don't think many others have tried it (nor felt the need to). If you're tri-wired, as I am, it is extremely easy to try as I'm sure you're aware. If you have a recording that you find sounds thin and 'sucked out', see if reversing the polarity gives you better body and projection. Conversely, if you have a recording that you feel already has those qualities then see if the change is detrimental. I believe some folks who have the benefit of a phase switch in their system will move back and forth for different recordings. I haven't observed any negatives, but the benefits have been more obvious on some recordings than others.Sadly, the folks at Hyperion are not inclined to share their thoughts on the circle here. I don't know if there is any percieved conflict in manufacturers doing so. I would be interested to know if they agreed with the phase reports for the 968 and if they made any changes as a result of that review.I'd rather run my speakers as they were designed than with my custom crossover mods - which is what inverting phase on one of the drivers amounts to.I am now listening to these speakers with my Audio Note Kits DAC and pre and Audiopax 88 monoblocks, and this sound is exquisite. It does not get much better than this at any price. I find the Hyperion 938s to be wonderfully balanced and musical speakers, and extremely revealing as well.
