0 Members and 1 Guest are viewing this topic. Read 12280 times.
Quote from: *Scotty* on 30 Jun 2009, 11:58 pmIt's not clear whether or not the Diverter is an asynchronous or isosynchronous USB connection. It is also not clear if the SPDIF output is transformer coupled or not. Both of these questions need to be answered in order to make an informed buying decision.ScottyCircuit design, PCB layout and skill of the designer/engineer are the most important things to consider in a design like this. Some will get it, some won't, and that's cool.Lee
I think your insinuation that the designer/engineer is dishonest in your post is mean spirited and out of place in an "industry ads" thread. Especially coming from a moderator of a different forum.FWIW, the designer has been a friend of mine for a very long time and is a the expert in the field of high speed digital design, I had to convince him to even take on a small project like this. His priorities are design for the medical and military industries, not designing relatively inexpensive products like this. FWIW, there is a six layer PCB inside the unit with multiple ground planes, you probably have never seen a PCB like this, unless of course you work in a company that does high end/high speed digital design.
Quote from: cryoparts on 1 Jul 2009, 01:40 amI think your insinuation that the designer/engineer is dishonest in your post is mean spirited and out of place in an "industry ads" thread. Especially coming from a moderator of a different forum.FWIW, the designer has been a friend of mine for a very long time and is a the expert in the field of high speed digital design, I had to convince him to even take on a small project like this. His priorities are design for the medical and military industries, not designing relatively inexpensive products like this. FWIW, there is a six layer PCB inside the unit with multiple ground planes, you probably have never seen a PCB like this, unless of course you work in a company that does high end/high speed digital design.I'm sorry Lee I didn't mean to offend. I just felt that he could have said he made the case look nice for monetary reasons (it must have been one reason!). I find it hard to believe that the PCB wound up looking like a four leaf clover. But if it did, I'm quite sorry. You have actually made me quite intrigued by this PCB, do you have a photo? Maybe you should blur it a bit for IP reasons?Also Lee, would you mind commenting on why you would use this instead of just using the S/PDIF from a computer?Again, sorry to offend.-West
Lee,Sorry for the dumb question but I have to ask. Does this nifty package output 16/44.1 and 24/96 or does it also pass through everything in between? I've been looking for a USB/SPDIF converter for use with Protools LE running native off of a MacBook Pro.By the way it looks great.Thanks in advance.Jack
[ You have actually made me quite intrigued by this PCB, do you have a photo? Maybe you should blur it a bit for IP reasons?
