How does directionality work with (series) coupling caps?
0 Members and 1 Guest are viewing this topic. Read 1995 times.
andyr
Some film caps have a preferred direction ... ie. one lead is longer than the other (which I think denotes the '+ve' lead?) or it has a 'dot' at the '+ve' end.
(I'm asking this because I'm about to get stuck into the cap upgrades to my GK-1!  :D )
Can someone explain how this works for coupling caps?  Obviously if you were using such a cap to bypass an electrolytic in a PS or as the parallel cap in, say, a 12dB/octave bass low-pass filter in a passive XO, the '+ve' end would go on the 'hot' wire.
But what about for coupling duty?  Is it simply a matter of taking the simplistic view and saying:
* on an input coupling cap, since there must be some current flowing, the higher voltage end is obviously at the input RCA ... so the '+ve' end of the cap should be connected to the RCA pin?
*  and on an output coupling cap, the lower voltage end is the "outermost" end ... so the '+ve' end of the coupling cap should be connected to the PCB and the other end soldered to the RCA pin?
Andy
AKSAphile
Re: How does directionality work with (series) coupling caps?
« Reply #1 on: 7 Jun 2009, 05:57 pm »
I would done it this way:
+ wire should go on middle "hot" pin of input RCA connector, - wire to the GK input
+ wire should go on GK output pin, - wire to the hot pin of RCA output
andyr
« Reply #2 on: 8 Jun 2009, 02:51 am »
Thanks, AKSAphile - will do.  :thumb:
Andy
