0 Members and 1 Guest are viewing this topic. Read 3495 times.
http://www.dlink.com/products/?pid=509I built one for a client. It worked well and it's cheap. Seagate Barracuda drives are known to work well with it, or read Newegg user comments for other drives known to work well.
One of the points of having a NAS is that it doesn't need to be anywhere near the computer. Put it in the next room, for instance.
HA! I didn't know it had a fan. Thanks. With the Dlink 323 sitting on the desk right next to me during setup, all I could hear was disk activity while it formatted. Once disk was done, it was silent from only ~3 feet away. I never noticed any fan noise from it, and I am hyper sensitive to that kind of noise because I own a ReadyNAS NV - now that's a really LOUD FAN! I'm sure you will find the 323 to be quiet enough to place in the audio system. You could return it to NewEgg if you don't like it. Good luck
Actually, I may not need a NAS? Essentially, all I want is 2 x 1TB disk drives in a RAID 1 (mirrored) situation for backup reasons.
Do a google search for "raid is not a backup" and you'll (hopefully) come to the conclusion that you don't need or even want RAID.What you really should be looking at is two external drives in enclosures. One for your library and one for a backup. Keep the library drive attached. Backup occasionally and put the backup drive some place safe. There are many enclosures that are fanless, most of them close-fitting metal cases that are able to radiate heat. The 5400 RPM Western Digital green drives don't get very warm at all, so will be safe.
I was thinking of those WD "Green" drives but I thought they had to fit inside an enclosure ... are you saying they are enclosed so they can just sit on the desktop, next to the PC?
So how would I connect the individual disks to the PC - USB connection? If so, is this fast enough?
And yes, as long as I backup every week, say (assuming I'm ripping LPs to disk quite often), I will have a redundant store of ripped LPs.
If you buy bare drives, they'll need to be placed in enclosures.
Exactly. Backup as often as you feel comfortable. Just keep in mind that if the library drive crashes you'll lose everything you did since your last backup.
OK, so I should be able to buy the WD 'Green' drives with enclosures? I'll research this.
