274A on Apollo's Power Supply
0 Members and 1 Guest are viewing this topic. Read 6279 times.
icefox
« on: 4 Jun 2009, 09:17 pm »
I know it's a bit crazy but I want to make sure it is possible before I try.
Nicolas, would you please let me know if it's possible to use 274A rectifier tube (with a 4pin to 8 pin adapter) in the power supply of the Apollo, replacing the 5Y3?
PromitheusAudio
    • Promitheusaudio
Re: 274A on Apollo's Power Supply
« Reply #1 on: 5 Jun 2009, 01:52 pm »
Should not be a problem
the apollo power supply uses a choke input which allows many times of rectifer to be used.
Like you said if you get the 4pin to 8pin should not be a problem then
zoltm2001
« Reply #2 on: 19 Jul 2009, 07:21 am »
I did tried to roll a WE 274A, 197x vintage to the Apollo. It was a jaw-dropping experience. The performance jump 3 classes, able to rival the MFA Silver Passive Pre.
Mine is an EI core Apollo. I wonder if a C-core TVC-upgraded Apollo would provide further jump.
I am so surprised how sensitive the Apollo is in terms of rectifier rolling.
PTC
« Reply #3 on: 28 Jul 2009, 09:33 pm »
I have a TVC with the active tube linestage and the rectifier tube in the power supply has 5 pins??? It is several years old have things changed???Peace,Paul
zoltm2001
« Reply #4 on: 5 Aug 2009, 12:54 pm »
Paul,
I believe nothing has changed. The power supply should typically be an octal base. I use a converter to play with 4 pin rectifier tube.
If you need that PM me.
Thx
PTC
« Reply #5 on: 5 Feb 2010, 09:50 pm »
Anyone know where I can get one of these converters???Peace,Paul
redabook
« Reply #6 on: 16 Feb 2010, 05:41 pm »
Have a look at EBAY item number 320483364271. Might be what you are looking for.
PTC
« Reply #7 on: 16 Feb 2010, 06:09 pm »
That looks like it Thanks,Paul
