Physics of subwoofers: boxed / OB / IB
dvenardos
Re: Physics of subwoofers: boxed / OB / IB
« Reply #20 on: 4 Jun 2009, 05:45 pm »
SPL= Sound Pressure Level.  If you can hit the same volume with both solutions I can't see how the OB will pressurize the room less since volume is a measure of pressure.
Because dipole radiation is pressurizing a localized area and not the entire room.
It is like a bullhorn. If you are off to the side you can't hear it as well.
Here is the webpage of the radiation pattern:
http://www.kettering.edu/~drussell/Demos/rad2/mdq.html
Bob in St. Louis
« Reply #21 on: 4 Jun 2009, 06:13 pm »
"Typical" subwoofer = Grenade
Open Baffle = Claymore
Stereodude
« Reply #22 on: 4 Jun 2009, 06:15 pm »
Quote from: dvenardos link=topic=68547.msg635562#msg635562
Yeah, but is the sub actually a dipole at 22-29Hz?
dvenardos
« Reply #23 on: 4 Jun 2009, 06:20 pm »
The wave pattern would be the same regardless of frequency. Just because the human ear can't normally localize the sounds below 80hz doesn't mean that they propagate differently.
