Desperate days due to dire DAC disaster.
0 Members and 1 Guest are viewing this topic. Read 1322 times.
chadh
« on: 31 May 2009, 05:04 pm »
My wife turned the stereo on this morning, so we could enjoy some tunes with the morning coffee.  But instead of the Roy Haynes Trio ringing out bright and clear, we heard only a shadowy specter of the trio fighting a losing battle against a hailstorm of static and noise.
I had no idea which portion of the audio chain was responsible.  But I replaced the PC and USB DAC with the DVD player from the basement, and (playing CDs for the first time in a couple of years) the music sounded fine.  I swapped out laptops, and returned the USB DAC to operation, and everything fell apart again.  I then removed the DAC and replaced it with a TASCAM US122 USB music interface, and, although this sounded pretty awful, it was clearly working properly.
So, it seems like my DAC is screwed up.
But I have no idea why.  It was working fine last night.
Interestingly, my wife tells me that the microwave, basement PC and oven all needed to be reset this morning, as though we had had a power failure last night.  I don't think we had a lightning storm.  No breaker had been tripped.  It seemed just like a simple power failure.  Could that have damaged the DAC somehow?
Any suggestions for what I should do, other than contact the manufacturer for instructions?  Any ideas for what might have happened?
Chad
chadh
Re: Desperate days due to dire DAC disaster.
« Reply #1 on: 1 Jun 2009, 01:19 am »
No ideas?
I'm desperate to get things back to normal.  Currently, I have the Tascam US-122 operating as DAC and, honestly, it's terrible.  There are so many pops and skips, I keep thinking I'm listening to a really old, really scratched, LP.
Chad
ecramer
« Reply #2 on: 1 Jun 2009, 01:29 am »
What make is the dac?
chadh
« Reply #3 on: 1 Jun 2009, 01:53 am »
It's one of Peter Daniel's Audio Sector USB DACs.
Chad
chadh
« Reply #4 on: 1 Jun 2009, 06:12 pm »
Disaster downgraded!
Peter suggested that I switch everything off for a while, and then to try the DAC again.  And, guess what?  Everything is working properly now!
I wonder whether turntables sometimes don't work, and need to be turned off and given a rest before they sound right?  Or is it only digital sources that need little vacations every now and then?
Anyway, thanks go to Peter for quick response to my problems, and for an embarrassingly easy (if somewhat perplexing) solution.
Chad
