KT66 question
0 Members and 1 Guest are viewing this topic. Read 1494 times.
Ericus Rex
KT66 question
« on: 29 May 2009, 11:59 am »
Hi Guys,
Are KT66s and 6L6s interchangeable?  My amp accepts 6L6 tubes and I wonder if it will take KT66 as well.  What got me thinking about it is all the ebay ads for KT66 that also show 6L6 in the heading.  If they aren't interchangeable, what are the differences?
Listens2tubes
Re: KT66 question
« Reply #1 on: 29 May 2009, 12:09 pm »
Yes. There's a good explanation of this here http://www.srl.utu.fi/~tke/MesaBoogie/Tube/6l6review.html
Enjoy!
Niteshade
    • Niteshade Audio
Re: KT66 question
« Reply #2 on: 29 May 2009, 01:26 pm »
KT66's  need more heater current (1.27a) Than a 6L6 (.9a). This may or may not be a problem depending on your amp's power transformer spec's. If you can use El34's, there won't be any problems.
« Last Edit: 30 May 2009, 11:07 pm by Niteshade »
Ericus Rex
Re: KT66 question
« Reply #3 on: 30 May 2009, 11:24 am »
So if my amp will accommodate EL34s, 6L6s, KT88s and 6550s it should have the power trans to handle KT66s?
Niteshade
    • Niteshade Audio
Re: KT66 question
« Reply #4 on: 30 May 2009, 11:08 pm »
That's what I would think, yes. You might have to change the bias a little. Just keep track of how much heat they dissipate.
