0 Members and 1 Guest are viewing this topic. Read 210869 times.
Thanks for the advice. Was just reading up on house curves, and came across some good links, so posting here for any others interested:http://www.hometheatershack.com/forums/rew-forum/96-house-curve-what-why-you-need-how-do.html#post448http://www.hometheatershack.com/forums/rew-forum/6818-minimal-eq-target-levels-hard-knee-house-curve-long.html#post55647Nuance - do you use only sub eq, or do u eq the rest of the frequency range too? Links above suggest dialing down the higher frequencies too..Now if only Jim could get the speakers made, I can start trying all this out
I added my name to the waiting list. I jumped on a pair of SoundScape 10s before the price increase. Yikes!
Congratulations! I thought about going into debt and just purchasing some HT2-TL's before the price increase goes into effect, but my rational side just wouldn't let me do it.
Congratulations! With your system they should sound kick ass! Bob
If these are not the cat's meow, then I'm coming after you. ; )
Thanks for putting together a review on yours.
I am sorry that I missed this question. I only EQ below the crossover, as I believe one shouldn't EQ above the Schroeder Frequency. That's highly debatable, of course, and I would never force my opinion down someone's throat. Well, unless they say Salk speakers are bad; then it's on! LOL!
It's time to consider placement options. I may need to move these closer to the back wall than my HT2-TLs were to enhance the rear wave?
Been lurking around the forums quietly thus far, though now I put my deposit down on my new songtowers + songcenter + custom dye job (more on this later) and so I'm anxious to get my name on the list Ordered - sep 15Expected delivery - Nov 15 or better
Things I plan to do while I wait in rough order of priority:1) Work on improving my room with some modest room treatments. 2) Ordering Blue Jeans Cables for my new setup.3) Trying to figure out the best way to take room measurements (REW maybe). I have a Radio Shack SPL meter and have mapped out the Bass frequencies using test tones and found my room to be pretty flat all things considered, so maybe that's enough.4) Reading Floyd E. Toole's Book "Sound Reproduction"5) Obsessing over what I should do to upgrade my Onkyo 807 (if anything)6) Considering future upgrades to my HSU STF-2 Sub7) Trying to decide if I really want to add a turntable to my system (and then obsess over finding deals on used LPs)
correctionplaced my order on Soundscape 10's Oct 28thneeded to work out details on veneersall I can say is Jim is a very graceful and patient manwhat preparations while waiting?keep enjoying my HT3'sconsidering getting TRL Samson monoblocksone piece at a time grasshopper
Did you quiz Jim on the sound of the Samsons since he has heard them?
