4-conductor + shield; purpose?
0 Members and 1 Guest are viewing this topic. Read 1016 times.
James Romeyn
« on: 26 May 2009, 11:29 pm »
I found some Canare L-4E6S, 4-conductors + braided shield (no idea of the source).  Strangely, only two insulation colors for the 4-conductors (two white/two blue); one might expect 4 different colors to differentiate them.  What are common uses for this cable?
Thanks.
BradJudy
Re: 4-conductor + shield; purpose?
« Reply #1 on: 26 May 2009, 11:38 pm »
It's a star-quad geometry microphone cable - http://www.canare.com/ProductItemDisplay.aspx?productItemID=53
This page explains the star-quad approach and how to connect it to a microphone XLR connector: http://www.canare.com/UploadedDocuments/Cat11_p35.pdf
James Romeyn
« Reply #2 on: 26 May 2009, 11:44 pm »
What took you so long?   :lol:  Very nice!  It looks like Canare's point is to increase the NR effect by increasing the density of integration of the opposed signals; simple & effective I suppose.
Is it generally acceptable to employ 2-conductors + braided shield for balanced interconnects, in which case the braid is earth + shield?
When using 3-conductors + braided shield for balanced interconnects is the shield connected on the load only & open on the source or connected both ends?  (Making a hard-wired box; cables not reversible once assembled.)
Speedskater
  • Kevin
« Reply #3 on: 1 Jun 2009, 09:20 pm »
Four conductor star-quad cable is more symmetrical than most two conductor cable. Even the small difference in the insulator thickness of the individual conductors can have an effect on this symmetry and a spiral drain conductor can have a greater effect.  In a balanced circuit, symmetry is important for high frequency common mode noise reduction.
