Virtue 2 digital amp feedback
0 Members and 1 Guest are viewing this topic. Read 12480 times.
se-riously
Re: Virtue 2 digital amp feedback
« Reply #20 on: 28 Dec 2009, 06:43 pm »
Danny,
I had a question about upgrading the coupling caps on the Virtue One to Sonicaps.  Are these the caps that would be replaced?
If not, what values would be needed for the upgrade?  Thanks in advance.
Angaria
« Reply #21 on: 29 Dec 2009, 02:20 am »
Have you thought about the.... virtues of the battery-powered Virtue vs battery powered Dodd amp?
Danny Richie
« Reply #22 on: 29 Dec 2009, 03:25 am »
Yep, those are the caps to replace.
I will actually be having a group of the amps made with the Sonicaps. So you will be able to order them that way if you want.
Have you thought about the virtues of the battery-powered Virtue vs battery powered Dodd amp?
I have had them both. What would you like to know?
OzarkTom
« Reply #23 on: 7 Jan 2010, 01:54 pm »
Hi Danny, will you be offering the new Virtue Sensation amps with the sonic caps also? Any thoughts on how these will perform?
Tom
Danny Richie
« Reply #24 on: 7 Jan 2010, 10:31 pm »
Just the smaller amps to start with, but you never know. We'll see where it goes.
dvenardos
« Reply #25 on: 8 Jan 2010, 12:19 am »
I was wondering the same thing.
Danny, how do you like the sonicaps with the Virtue versus the auricaps?
I like the auricaps in the Two better than the custom caps in the One.
Danny Richie
« Reply #26 on: 8 Jan 2010, 12:24 am »
Typically Sonicaps are a little cleaner and have less coloration in all applications that I have tried them both in.
