0 Members and 1 Guest are viewing this topic. Read 6184 times.
Thanks guys. I appreciate your efforts to enhance my musical experiences. I've toyed with the idea of a sub before, but never seriously. My amp is handily equipped, though, with one set of full range outputs and one set with a high-pass filter.Chad
I suspect that Roger has employed something very similar to the PLLXO idea you suggested, but has simply built it into his amp just before one of the sets of binding posts.
Quote from: chadh on 25 May 2009, 06:27 pmI suspect that Roger has employed something very similar to the PLLXO idea you suggested, but has simply built it into his amp just before one of the sets of binding posts.Anything just before the binding posts is not going to be a PLLXO -- it would effectively have to be a passive loudspeaker XO.The filtering should ideally happen between stages which means it would really need a switch.dave
Hmmm...I was thinking about a pair of these. But I don't think I can get them in the same finish as my Omegas.Chad
Focusing on the high-pass filter, though: I'm wondering why one cares whether this filtering occurs prior to amplification (in which case it might qualify for description as a "PLLXO") or after amplification (in which case it becomes a lowly passive speaker crossover)?
