0 Members and 1 Guest are viewing this topic. Read 6688 times.
Quote from: lonewolfny42 on 28 May 2009, 02:14 pmGene....What amp are you using with your TP's ? Thanks... Hi Chris,The only other nut I can remember that has both the Mini's and TP's in house at the same time. Although my Mini's are on the way out the door today. As far as my amp, I've got the Spectron. I know I've never used but a small fraction of its capabilities but at the time, I didn't want any regrets. One day, I'll aim the TP's at the windows, put on my headphones for protection, crank it up and see if anything breaks. Gene
Quote from: Goosepond on 28 May 2009, 03:54 pmQuote from: lonewolfny42 on 28 May 2009, 02:14 pmGene....What amp are you using with your TP's ? Thanks... Hi Chris,The only other nut I can remember that has both the Mini's and TP's in house at the same time. Although my Mini's are on the way out the door today. As far as my amp, I've got the Spectron. I know I've never used but a small fraction of its capabilities but at the time, I didn't want any regrets. One day, I'll aim the TP's at the windows, put on my headphones for protection, crank it up and see if anything breaks. Gene.....Thanks Gene. Your scaring the glass panes..... Yes...I still own both...and always will. Now the Minis are sitting on top of the TP's...a little variety...switching back and forth....just don't have the room here.As I have heard the whole line....as you move up it just gets bigger and better....as your finding out.But owning a TP is a good place to be....enjoy....
I noticed when mounting the TP's on my stands, there is a panel of some sort on the bottom. I haven't really looked at it close because anything to do with those monsters takes more muscle than I've got.
But I've asked Bob if those are removable to allow adding the lower box that turns them into the mysterious Mini-Revelations. Do you know?
I think I'll finally go and propose I start a hirez music forum here. It will be about all things hirez audio (pc music, multichannel music, Blu Ray music, how to rip DVD-Audio, DACs that handle 24/192, etc.)
Quote from: ted_b on 28 May 2009, 03:08 pmI think I'll finally go and propose I start a hirez music forum here. It will be about all things hirez audio (pc music, multichannel music, Blu Ray music, how to rip DVD-Audio, DACs that handle 24/192, etc.)I believe it when I see it
