Mapletree 2A SE - what compares <$1000
0 Members and 1 Guest are viewing this topic. Read 2850 times.
droht
« on: 13 May 2009, 04:35 pm »
I would love to pick up a Mapletree 2A SE pre.  Wondering what else I should be considering in the price/performance range?
I currently have a Virtue TWO amp (and always thinking about an Odyssey or Khartago) and really would like to try a tube pre.  Currently using a Keces DA-152, which I think does a great job, but I want to see where tubes can take the sound.  Current speakers are Ushers S520s, but I will have a pair of single drivers utilizing Fostex FX120s soon.
Appreciate any suggestions.  No DIY for me.
rockadanny
Re: Mapletree 2A SE - what compares <$1000
« Reply #1 on: 13 May 2009, 04:58 pm »
Wright WLA-12A Tube Preamplifier perhaps? I have not heard one (sorry) but did consider this one when looking. I ended up buying the Mapletree in the end. And I am very glad I did. It is really good.
Review of the Wright...
http://www.hometheaterhifi.com/volume_7_2/wright-parasound-preamps-5-2000.html
BillB
« Reply #2 on: 13 May 2009, 05:33 pm »
I think the virtue does really well with a tube pre. I used my design on it and it really took it up a notch (or 100 IMO).
I still have a VTL I can sell you for a really good deal man.
dweekie
« Reply #3 on: 13 May 2009, 05:56 pm »
Haven't heard it, but another well regarded option.
http://www.transcendentsound.com/preampkit.htm
ebag4
« Reply #4 on: 13 May 2009, 06:02 pm »
There is an SAS 10A on Agon right now:
http://www.audiogon.com/cgi-bin/cls.pl?preatube&1247374418&/SAS-Audio-10A-tube-linestage-p
I have never heard one but I have read great things about them.
Best,
Ed
JimJ
  • Ut Prosim
« Reply #5 on: 13 May 2009, 06:56 pm »
Maybe talk someone out of an Audible Illusions Mod 3A? :)
I loved mine...
Other ones I'd consider would be a Decware CSP2, ARC SP-9MKII (used) or a Transcendant GG...
Lots of good options out there for $1k.
droht
« Reply #6 on: 14 May 2009, 03:21 am »
Thanks for the replies and suggestions.  I will check these out.
droht
« Reply #7 on: 18 May 2009, 02:34 pm »
I've been reading about a variety of these options, and honestly it would be a coin toss for me to select one over another.  The Mapletree is a clear winner in style to me.  I hate to buy audio gear based on that, but if that is all I have to go on I suppose it is not such a bad thing.
droht
« Reply #8 on: 18 May 2009, 03:42 pm »
What about Eastern Electronics MiniMax?  Just stumbled across one on AgoN...
bacobits1
« Reply #9 on: 18 May 2009, 04:55 pm »
The EE Pre is an excellent little pre and responsive to tube rolling tastes.
I owned one for 3 years. Can be had used for $600.
Den
spendorite
« Reply #10 on: 19 May 2009, 01:48 pm »
Apart from the Mapletree 2A SE I have'nt heard any of the other preamps mentioned here.  Based on performance I would consider the Mapletree to be the equal of any of them if not better.  Based on price I think it would be the hands down winner here. Just my opinion.
