Can this room use more panels?
0 Members and 1 Guest are viewing this topic. Read 2445 times.
n2siast
« on: 11 May 2009, 03:18 pm »
« Last Edit: 11 May 2009, 06:31 pm by n2siast »
bpape
    • Sensible Sound Solutions
Re: Can this room use more panels?
« Reply #1 on: 11 May 2009, 03:53 pm »
Not seeing anything in your post - no text, no pics.
Bryan
Ethan Winer
  • Audio expert
« Reply #2 on: 11 May 2009, 04:49 pm »
He probably needs more panels anyway. :lol:
bpape
« Reply #3 on: 11 May 2009, 05:08 pm »
OK.  We have one now.  Any chance of seeing the rest of the room?
Bryan
n2siast
« Reply #4 on: 11 May 2009, 06:33 pm »
n2siast
« Reply #5 on: 11 May 2009, 06:34 pm »
n2siast
« Reply #6 on: 11 May 2009, 06:38 pm »
bpape
« Reply #7 on: 11 May 2009, 06:47 pm »
The room looks to be very tall.  You could potentially use:
- a little more of something on the front wall up high
- Broadband bass control in the rear corners
- Potentially some diffusion up high on the other walls
- Diffusion on the ceiling depending on what the floor is like.
Bryan
Carlman
« Reply #8 on: 11 May 2009, 09:08 pm »
You have a giant cube.. I'd recommend a lot of diffusion and corner treatment if you can get away with it.
Anything is better than nothing.  I've been in many rooms exactly like that.  It is tough to tame.
Absorptive panels are fine in specific locations but you'll end up hearing a lot of reflectivity behind you in that setup.  It's got to be balanced out... I'd try spreading the panels out to hear how that changes things first.  Consider a floor standing panel to separate the kitchen.. even something small (like a 2'x4') behind your head might work.
Without diffusion you will essentially need to cover that entire room with panels.  Start reading up on diffusion.  If you get the diffusion right you can use some of the panels you have as bass traps.
Another option is to hire an acoustic designer to come in.. like Rives or someone like that.  They'll give you the exact answer (at a fee of course).. but just throwing out some ideas.
-C
srlaudio
    • SRL Acoustics
« Reply #9 on: 19 Jul 2009, 06:01 pm »
I echo the previous post, and I can definitely help you get the diffusion right!
