0 Members and 1 Guest are viewing this topic. Read 7744 times.
I've read that lowish inductance is favorable for an OB woofer. Is 1.495mH considered low?Thanks again folks!
Any comments on the appropriateness of this driver:http://swanspeaker.com/product/htm/view.asp?id=326
I simulated a configuration that would allow the B200 to work above 200 Hz. Your baffle should be 40 cm wide and 120 cm tall with the B200 mounted at 90 cm. If 80 cm for the B200 would be ok, you could shorten the baffle to 110 cm.
My baffles have already been cut, including the driver holes for the B200.They are 115cm tall x 41cm wide, with the driver center at 90cm. Being that the total height is 5cm shorter than you suggested, will this be a problem?
How would one achieve a 200hz high pass on your suggested circuit? Although I will likely use a pair of plate amps to drive my woofer system I would rather not utilize the on board high-pass filters for the B200's.
