0 Members and 1 Guest are viewing this topic. Read 17455 times.
Oops, I see from reading this thread more thoroughly that you may have already damarred the whizzers, and had considered, but balked at the EnABL treatment. If you look closely at the photo posted by Mike, you'll note that they the treatment applied.
Quote from: chrisby on 5 Jun 2009, 10:07 pmOops, I see from reading this thread more thoroughly that you may have already damarred the whizzers, and had considered, but balked at the EnABL treatment. If you look closely at the photo posted by Mike, you'll note that they the treatment applied.I will dammar the whizzer. I ordered from my art shop 100g of raw dammar gum that i will dissolve and prepare myself.But i do not have the time to do the full enable treatment. It will be more cost-savvy for me to buy more expensive drivers
After listening for a while you may want to add another woofer to make it dual woofer, then the speaker pair will last you for some time. That is my experience.Cheers, happy listening.
The Beyma is very pretty. If it sounds as good, you'll be happy!
Just as a reminder, he is my old hemp OB rig. Selenium 15s on the bottom. Pine and bamboo baffles.
I choose pine because it was cheap, easy and thick. The bamboo is only 1/4" thick on these, so is only to "make pretty." I have used 3/4" bamboo ply, it's very nice but very $$. 6cm depth? That's a lot.
I hope you don't get problems with resonances in the driver holes.
As for driver placement, I did some sims in "The Edge" software. Never found a perfect placement, so did the best i could. FR8s were more or less at ear level, 15s near the floor for some bass boost. Wings asymetric. I did run them with the FR drivers inside and outside. Both worked, dont' know which was better - just diffrent.
Hi Telstar,I like it when people see (better: hear) real progress!To me it always has been difficult to judge the potential of a system from the quality of separated components or to mentally mask out inferior parts. It only fell together when everything was integrated on a comparable quality level. Looks like you have reached that point.
I'm happy that you like the bass level and performance.
You should have fun doing the minor changes and improvements that will give you even more satisfaction.
Your baffles blend so well with the floor - it would be a pity to discard them for other ones anytime soon.Rudolf
