old Mac Mini versus new Mac Mini
0 Members and 1 Guest are viewing this topic. Read 2319 times.
rydenfan
« on: 7 May 2009, 11:52 pm »
I am about to pull the trigger on a Mac Mini for a server. I have heard grumblings that I want to buy the last gen model as it has Firewire 400 while the new ones have Firewire 800. Would love to hear from those that know more than me.
jtwrace
    • TIPP YouTube Channel
Re: old Mac Mini versus new Mac Mini
« Reply #1 on: 8 May 2009, 12:54 am »
If you are going to use it as a stand alone server, you will be fine with either one.  Personally, if you can spring for the extra bucks get the new one for the upgrades processor.  If not, there will be no sonic difference.  That's all you need for a server.  I've got a very large library and it works great!  I also have two 1TB iomega HD's connected via Firewire 400 and use SuperDuper! as my backup (bootable backup) software.
persisting1
« Reply #2 on: 8 May 2009, 01:20 am »
One of the problems is that many people have external drives that only use firewire 400.
Get an external HDD with firewire 800 and you're set.
Go with the new like jtwrace stated.
santacore
« Reply #3 on: 8 May 2009, 01:38 am »
You can also buy a 800 to 400 cable. Problem solved.
jtwrace
« Reply #4 on: 8 May 2009, 11:33 am »
I've found this place to have the best prices:  http://firefold.com/Firewire-Cables-and-Products-C6.aspx
