0 Members and 1 Guest are viewing this topic. Read 6783 times.
I am going to disagree with you on this. I recently got the new input board upgrade for my MSB Technology Platinum DAC III. This provides the ability for 8X upsampling, which can be engaged from a front panel switch. Three other pair of good ears were here two days ago. We selected among four different ways of getting from the CD transport to the analog inputs of the preamp:
I'm in full agreement on this one Blair. I've yet to hear any hands-down improvement when comparing upsampled 44.1k recordings from my hard drive to say 48k or 96k. For me, upsampling robs the music of it's life, especially in the highs. But that's just in my system, maybe higher grade upsampling gear can make improvements? In my system, it's strickly 24/44.1k playback. Cheers,Robin
The purpose of upsampling is not to gain resolution. If it was, you could record music to 8-bit/100hz, then upsample it on the CD player and fit hundreds of hours of high quality music on a CD...Upsampling is done to help filter out high frequency digital "artifacts" without impacting the audible spectrum. When a DAC converts a digital signal to analog, slight inaccuracies in this process introduced artifacts at just over the replay frequency; at 44khz sample rate, artifacts are introduced at just above 22khz. Non-upsampling DACs require an analog filter be placed at just above 22khz to eliminate those artifacts...by being so close to the audible frequency, it is assumed that its possible for some of these filters will impact your listening experience. By upsampling to a higher frequency, a DAC essentially moves those artifacts to a higher frequency, farther from the audible spectrum, and making them easier to filter out without impacting the audible frequency spectrum.There are probably a few other reasons for doing it, but this is my understanding of the initial reason for upsampling...
I get mixed up which is upsampling and which is oversampling. I thought the 44khz part was oversampling and the bit was upsampling, but I could have them backwards. The khz is the part affecting the filter.
Quote from: wilsynet on 1 May 2009, 01:54 amupsampling != oversampling.It might very well be true that it's also non-oversampling, but then I'm confused about the role of the superclock.Oversampling is synchronous and does add more sample points. The purpose is to enable digital filtering. I think the algorithm is fairly simple. In the Overdrive, this is selectable, so you can push the digital filtering up in frequency until it has very little effect. Looking at the waveform on the scope reveals that the classic "stairsteps" of the D/A waveform are there, just like they would be on a NOS DAC.Upsampling is asynchronous usually and also adds more sample points. The algorithms can be complicated and take a lot of compute power. Usually the sample-rate is changed to a higher standard such as 44.1kHz to 96kHz.The Superclock is used both in the USB interfaces and the Pace-Car to reclock the data without changing the frequency, in order to reduce jitter. Clocks are simply used to move the data from point A to point B. Digital data must be clocked in order for it to move from one point to another. The clock that is used to move the data is changed from the computer clock to the Pace-Car Superclock or Off-Ramp Superclock.Steve N.
