0 Members and 1 Guest are viewing this topic. Read 4981 times.
I've just about convinced my wife that we should embark on a new adventure, adding a PC and USB DAC to the audio system. This is to replace the modified squeezebox I've been using. I have Peter Daniel's Audio Sector USB DAC shipping to me next week. Now I just need a PC.My needs for the PC are humble. It will only NEED to do two things:1) stream music very, very quietly to the USB DAC; and2) allow me to control which music is being played.This means it only needs to have enough processing power to run something like Foobar smoothly. It will be connected to my household network via ethernet cable, and music will be stored on another computer.But I also care about a convenient way to interface with the PC.Jrebman has suggested using an Asus EEE box. It's meant to be super quiet, and it's CHEAP. But to interface with this, I'd need to add screens and keyboards, or have a laptop open or something like that.In the same vein, I have been looking at this: http://www.newegg.com/Product/Product.aspx?Item=N82E16883220008&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Desktop+PC-_-ASUS-_-83220008That Newegg price of $479 is the best I've found.The problem is, the reviews of this item haven't been great. The touchscreen strikes me as a super convenient way to interface with the music system. But the touchscreen software isn't all that flexible, and it might be tricky to get really good control of foobar that way.I've considered using something like the Asus box, headless, and then adding a Nokia N810 to control it.Are there other super quiet, no frills PC options that fit my needs, and also turn out to be super cheap?Chad
I think NYC Paramedic around here (http://www.audiocircle.com/index.php?topic=62364.0) posted about a SBC Linux build he did. Very low power, and runs music well. Typically run headless.You do still need a device to control it (Netbook, laptop, Blackberry, Nokia, some wifi device), but for the $140 or so he spent, and the low low power consumption, it might just be the trick. They do have USB ports too.
I cannot speak to simpler or not, and I assume that he already has a laptop?The Dell mini 9, at around $280 US, does seem good, but he still needs a remote device to alter music and volume via Foobar - no?Not suggesting it is not a good solution, but if you still need the remote, then isn't it just 2x the price of the SBC solution? I do get that it has a screen etc, and is easier to admin directly, but I have had great success running headless and doing admin via remote desktop.
My needs for the PC are humble. It will only NEED to do two things:1) stream music very, very quietly to the USB DAC; and2) allow me to control which music is being played.This means it only needs to have enough processing power to run something like Foobar smoothly. It will be connected to my household network via ethernet cable, and music will be stored on another computer.In the same vein, I have been looking at this: http://www.newegg.com/Product/Product.aspx?Item=N82E16883220008&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Desktop+PC-_-ASUS-_-83220008That Newegg price of $479 is the best I've found.
What will a PC and USB DAC do for you that a Squeezebox and external DAC won't? (I'm just curious. I haven't spent much time with a Squeezebox, although I know how they work.)
This is where a Dell Mini 9 would fit in. You could even get one with Windows on it if you'd rather have that. You don't need to store music, so a very small solid state HD would be fine.They're very small and lightweight, and there's no noise because there is no mechanical HD. They also boot really fast.
Anthony A.,What was the power supply you found for your eee box? I've got essentially the same setup in one of my systems -- eebox to AS NOS dac.-- Jim
Moreso than worring about the quality of the PS for the PC, I assume it is more concern around not polluting the AC that leads to your DAC.You might want to use Felix/Felicia's or some other balanced power conditioner on any SMPS near your DAC...
