Recommend a tube for my Peachtree Decco...
0 Members and 1 Guest are viewing this topic. Read 1961 times.
TKonrad.NOLA
« on: 24 Apr 2009, 05:00 am »
this is the first piece of equipment that I have ever own with a tube in it.  I have read that changing out the stock russian tube would make a significant difference.  What tube would you suggest I try?  Its a 6922 tube.
Re: Recommend a tube for my Peachtree Decco...
« Reply #1 on: 24 Apr 2009, 06:10 am »
The usual suspects - Amperex and Siemens are about the best you can get (sometimes labeled as 6dj8), with GE and Philips being a slight step down, but still far better than the Sovtek russian tubes.
