0 Members and 1 Guest are viewing this topic. Read 8130 times.
Bigger is better for A/V rooms, but proper ratios are even more important. With larger rooms of the right proportions and speaker/listener locations the benefits of room treatments (or EQ) become far less significant. I've added six GIK 244 panels at front corner and front/side wall first reflection points, but the effect is minimal.Insulation! Use simple fiberglass batt insulation for walls. Use an insulated exterior fiberglass door with weather seals (the fiberglass usually comes with a wood graining texture that takes paint or wood staining very well). Float the ceiling if there is living space above and add insulation above. (Floating the ceiling can be done in a variety of ways.) The flexible ductwork orthobiz mentions should be lined to keep fiberglass out of the room (and your lungs). Wire the audio circuits to the top of your primary electrical panel and provide them with a common, but separate (from the rest of the house) ground. Use 20 amp hospital grade wall receptacles (which can be bought cryogenically treated). Avoid: Windows, using upstairs rooms (wind noise, noise from below), penetrating the ceiling with any lights if there is living space above (maintain isolation), Other tips: Get all new household appliances and have the electrician install a whole house surge protector. Look for reliable power from a substation that is newer and doesn't have industrial users. Try to locate on a concrete slab floor. And remember that a real man cave will include a dead bolt that only you have the keys for. I did all the above (except the ceiling lights) and in the beginning it was spooky isolated (except for footfalls/washing machine/dryer above ). The biggest advantage is the flexibility to listen to what, when, and how loud you want. The other major advantages are to be able to listen at lower spls and to sit in the ideal spot. I can only hear the furnace/air conditioner after I've been in the room for awhile. As the builder normally insulated interior walls anyway, the electrician worked from a fixed fee, and we have solid cherry doors elsewhere in the house, the total cost to tweak the room for audio was less than $100.If you listen really loud, consider using 2x6 versus 2x4 wall framing (randomly varying the spacing from 8 - 16 inches), and use 5/8 inch drywall versus 1/2 inch.
Someone here at AC turned me on to this type of framing
Isolated grounds can be good in your audio system. BUT all the ground wires in your house must join at a common place (or before) in your main circuit breaker box. All ground rods and maybe the main water pipe must also connect to this same common place.
My audio epiphanies include transmission line speaker cabinet designs, single driver speaker designs, CDs (lack of vinyl/tape noise), and having an audio room.
Quote from: Speedskater on 3 May 2009, 04:46 pmIsolated grounds can be good in your audio system. BUT all the ground wires in your house must join at a common place (or before) in your main circuit breaker box. All ground rods and maybe the main water pipe must also connect to this same common place.I am not an electrician. If Code states all house grounds must join at a common point, can anyone explain why, in common language? The only thing that comes to mind is that anyone working on the system would know that there is a sum total of one location to diagnose a ground fault. Is that it? Does a 100-story highrise have one common point? Sorry for such a dumb question.
