Electrical confusion need advise
0 Members and 1 Guest are viewing this topic. Read 1026 times.
Nick77
« on: 22 Apr 2009, 03:07 pm »
I am planning a dedicated HT and listening room. The more research I do the more I am getting confused.  :scratch:
I am planning on 1 or 2 dedicated 20 amp lines to the room for just av equipment. I was thinking using 10/2 just for good measure. And using quality receptacles like Porter Ports or equivalent.
My question is should I use something like zero surge at the panel so that I can plug into wall outlets. I have heard that the wall is always your best bet?? I dont know if zero surge products compare to a good conditioner. I just know I removed my DAC from my Belkin conditioner and plugged it into the wall and the results were very positive.
Or do I skip the panel treatment and just plan on a good conditioner and less circuits??
I have heard the name Zero surge mentioned and their products are audio friendly and then there are quality items like Running springs conditioners but quite pricey.
What is a good economical route to audio friendly wiring during construction?  Thanks
richidoo
Re: Electrical confusion need advise
« Reply #1 on: 22 Apr 2009, 05:09 pm »
Congrats on the new room, man! That's awesome. I like Brickwall for surge protect. They make high current models for audio use. A whole house surge protect at the breaker panel is another thing to consider. For whole house, stick with a good brand name like SquareD or Leviton.
For conditioning I like magnetic types like Torus, EquiTech, BPT, Furutech ("symmetric" model), the latter three being balanced power which has additional advantages over the single ended Torus. Learn about balanced power on their websites. Filter type conditioners have their place too and I know people who prefer them especially in low current components, but I have not had good luck with them on power amps. I heard a Running Springs Jaco  (filter type) powering a McCormick DNA500 over the weekend, there was no deficiency at all. Tube amps seem to be more sensitive to the type of power filter. Mine benefited enormously from balanced power.
An advantage of magnetic conditioners is you don't need a dedicated line or panel which are intended to reduce impedance. The secondary "regenerates" clean, low impedance power with a large magnetic energy reserve in the transformer core.  The reserve allows current peaks without needing multiple high current dedicated lines. It's like having your own powerplant for your system. A single 15A shared circuit is enough to keep the core energized enough for the whole AV system.  Such a conditioner has a very large transformer, 15A model will weigh about 90 pounds, in 2 rack space box. If you have very hungry 500W monoblocks w/low sensitivity speakers plus 5 channel amp or hungry class A amps then get a 20A model.
I have never found an outlet strip that sounded good, even expensive TrippLite which got a good audio review. Plug your gear direct into the conditioner or wall.  Every temporary connection you add increases impedance, sometimes dramatically with cheap receptacles or brass blade plugs. Quality connectors and receptacles like Oyaide, Wattgate minimize impedance with firm grip and all copper parts. If you have a magnetic conditioner only the plugs that come after the conditioner matter. Anything before it is eliminated from the equation, as long as the resistance of the circuit doesn't pop the breaker. Reducing impedance before the conditioner will save power and probably improve performance, but to a lesser degree than the plugs after the conditioner. A single dedicated 20A line would be more than enough.  If you can afford $25/ft for the romex, JPS makes inwall wire that is incredible.
Use a recepticle tester to make sure your outlet is wired correctly and has a good ground. It's good to check every receptacle in the house just to be safe, especially on a newer house. A magnetic conditioner's huge transformer will uncover any mediocre connections in the line that feeds it, even blowing the circuit breaker. This indicates poor wiring, not the transformer's fault as long as the line is rated for the conditioner. Check that the receptacle's wires are screwed on, not backstabbed.
Good luck with your new theater, you lucky DOG!  :thumb:
mfsoa
« Reply #2 on: 22 Apr 2009, 09:24 pm »
And one more thing about the transformer-type power boxes vs. dedicated lines -
If you move to a new house, you unplug the box and take it with you. I'd hate to leave behind dedicated lines only to install them again in the next house. :duh:
And I guess for apartment dwellers a Torus-like thingee would be just the ticket for quality power.
-Mike
