satfrat - here are some FR and distortion curves from both. P.S. Anyone have a guide on how to read a distortion curve?http://www.zaphaudio.com/6.5test/
Rick,Now that you've had the opportunity to use both in several of your designs, do you believe that the ScanSpeak 7'' Illuminator woofers sound sufficiently ''better'' than the 7'' Revelators to justify the approximately $100 more that you pay for them?
Would be interested to know this as well, especially since the guy from Zaph thinks the illuminators are inferior
Hope Rick doesn't mind me jumping in here but I love looking at charts. First off, take all distortion measurements made outside of a chamber with a grain of salt. Taking good measurements that are representative of a production run is not as trivial as some people think. There are variations in production runs of drivers so it is more useful to look at a sampling rather than a single unit.Second... you have to consider the application for a driver. The Zaph measurements are without any crossover and outside of the final acoustic environment. Once you put it in a box with a port and add a crossover, the distortion measurements look different. For someone used to designing stuff, you can look at Zaphs measurements and know that your distortion will be another 30dB down at a given point so that rising distortion in the driver may be meaningless for the final build.Third.... types of distortion and where it is at is as important as a raw THD number. We are more sensitive to distortion in the midrange than we are at low frequencies. You can have fairly high low frequency distortion and not even know it. Also... high-odd order distortion products are more objectionable than low even-order products. It is very much the case that you can have a lower THD part that sounds much worse than a higher THD part because THD alone doesn't take into account the type of distortion. Both of the SS woofers look pretty good to me. The older one looks easier to work with but that cool motor design might be worth the extra $100 Just my 0.02
Is it really the distortion that makes ribbons sound better than domes to many people? Does it have nothing to do with a lower moving mass, faster attack and decay, higher extension that I thought would be the qualities of ribbons?
Quote from: kip_ on 22 Apr 2009, 03:19 pmsatfrat - here are some FR and distortion curves from both. P.S. Anyone have a guide on how to read a distortion curve?http://www.zaphaudio.com/6.5test/Kevin made some good points and I'll add a few things. Distortion is only one performance aspect of a driver. Zaph has made it his litmus test; however, a measurement is only worthwhile if it correlates with what we hear. For instance, he pretty much trashes ribbons for being inferior on distortion tests yet we and others like Salk Sound have had great success with them. So one must conclude one (or more) of the following:1) the tests don't show what we find to be accurate sound2) if you like ribbons you enjoy distortion3) the tests need to be made with a crossover in place to better reflect a normal listening situation4) other performance aspects of a driver are more important than distortion
Quote from: Kevin Haskins on 22 Apr 2009, 03:40 pmHope Rick doesn't mind me jumping in here but I love looking at charts. First off, take all distortion measurements made outside of a chamber with a grain of salt. Taking good measurements that are representative of a production run is not as trivial as some people think. There are variations in production runs of drivers so it is more useful to look at a sampling rather than a single unit.Second... you have to consider the application for a driver. The Zaph measurements are without any crossover and outside of the final acoustic environment. Once you put it in a box with a port and add a crossover, the distortion measurements look different. For someone used to designing stuff, you can look at Zaphs measurements and know that your distortion will be another 30dB down at a given point so that rising distortion in the driver may be meaningless for the final build.Third.... types of distortion and where it is at is as important as a raw THD number. We are more sensitive to distortion in the midrange than we are at low frequencies. You can have fairly high low frequency distortion and not even know it. Also... high-odd order distortion products are more objectionable than low even-order products. It is very much the case that you can have a lower THD part that sounds much worse than a higher THD part because THD alone doesn't take into account the type of distortion. Both of the SS woofers look pretty good to me. The older one looks easier to work with but that cool motor design might be worth the extra $100 Just my 0.02I don't mind at all your input when you agree with me.
I'm going to come late to this thread and post a few thoughts that might be helpful to someone looking at 7 inch drivers and trying to decide what to buy....One thing to consider about the Illuminator is it has a larger linear excursion, so in theory it could move more air. This means a number of different things, including the possibility of louder bass; also don't forget if you are using EQ at the low end this usually means some boost at the lowest octaves, and so you might benefit from increased excursion. Just one of many factors to consider. This excursion difference is one thing you can plug into simulations and so on, so it's a little more 'calculable' than the more subjective aspects of a driver like midrange resolution , etc.As regards Zaph's measurements, their value comes not from an absolute numerical characterization of each driver in and of itself, but from the ability to compare the drivers he tests to the other drivers he tests. This doesn't give you a definitive picture of the driver's performance, but it gives you important information when comparing these various drivers. Gives you a PART of the picture. Which is a good thing to have when working up a DIY design.For Zaph's tests of these 7 inch drivers, I like to look not at the absolute numbers of the distortion above 200~250 Hz, but the SHAPE of the distortion results- how quickly does it fall away as frequency rises, what is the relationship between F3 and F2 as frequency changes, and so on. This gives some information. What this all means to the overall sound will not be apparent to you until you work with some of these drivers or listen to projects other folks have made using these drivers. Nothing informs like direct experience. And of course looking at the breakup peak (if any) and it's impact on distortion will influence how you build a passive xover.SPEAKING OF TESTS I like the kind of tests that Siegfried Linkwitz puts drivers through, which include some dynamic tests (tone bursts) and so on. Voice Coil magazine also puts drivers through a gauntlet of tests, worth looking at to see if the driver you like has been tested at Voice Coil. They especially have a lot of "woofer centric" type tests relating to performance as an air mover.SIDE NOTE: I have to say that the Satori driver chassis look kinda like Illuminator.... and Satori drivers have pretty big allowable excursion numbers too...
