0 Members and 2 Guests are viewing this topic. Read 6681 times.
If a filter is rated for more current than the amp draws, I can't see a reason for such pronounced side effects. They're supposed to reduce high frequency components and do nothing else. I'm not saying you didn't hear what you heard- I'm looking for technical answers/reasons.
Some power cords twist their conductors to eliminate interference. That's a good idea. Twisting in conjunction with solid shielding sounds even better.
From my own experience, RFI/EMI manifests itself as buzzes, clicks and pops in my equipment- such as when the washing machine or AC turns on or off. BUT- I have never had this noise effect the tonality of anything I own. The power quality out here is decent, not above average. The voltage range is within specification of everything I own.
.........I have a few "high-end" cords and a Monster HTS-3600 power conditioner ($75 garage sale find). In my experience power cords have had little impact on my system's overall sonic signature. The greatest effect has been using two-wire PCs on tube amps. Three-wire cords have consistently caused noise problems. This was first realized when I rebuilt my Dyna Mk3 amps using Curcio premium upgrade kits and suffering low level hum with three-wire cords. Joe Curcio explained that the amps were not designed to work with three-wire PCs and as soon as ditched them my problem went away. I have found this to be basically true with all the tube amps I have used. Preamps, however, are another story.The Monster conditioner had a much greater effect on my system. When I had my amps connected I heard compressed dynamics. But using it with front-end components only I experienced greater focus and clarity without the dynamics problems.....
Jake,Quote from: JakeJ on 19 Apr 2009, 05:18 pm.........I have a few "high-end" cords and a Monster HTS-3600 power conditioner ($75 garage sale find). In my experience power cords have had little impact on my system's overall sonic signature. The greatest effect has been using two-wire PCs on tube amps. Three-wire cords have consistently caused noise problems. This was first realized when I rebuilt my Dyna Mk3 amps using Curcio premium upgrade kits and suffering low level hum with three-wire cords. Joe Curcio explained that the amps were not designed to work with three-wire PCs and as soon as ditched them my problem went away. I have found this to be basically true with all the tube amps I have used. Preamps, however, are another story.The Monster conditioner had a much greater effect on my system. When I had my amps connected I heard compressed dynamics. But using it with front-end components only I experienced greater focus and clarity without the dynamics problems.....While I do have a Monster HTS-3500 II on my 10yr old Sony projection TV, I'd never (again) inflict it on an audio system, certainly never on one as evolved as yours -http://www.audiocircle.com/systems/index.php?systemid=859If the Monster improves your system, a better conditioner should provide even more benefits to your front end components, as well as allowing your cords to perform at their best. Felix conditioners, much discussed in the Lab Circle, are an inexpensive way to explore, if you're amenable to diy, and don't value your own time. Ideally, you could borrow something like a Running Springs conditioner (there are certainly other excellent conditioners from other vendors) from a local audiophile. RS does make conditioners that are rated for amps as large as your VAC 160s, and others are happy with their appropriately sized Felixs for their tube monoblocs, but poweramps are the hardest challenge for conditioners.FWIW,Paul
....Other than using the proper gauge power cord for whatever's being ran- do you have any suggestion
Would you believe a conditioner/regulator to be that beneficial if the the entry system from the pole to your outlet is in prefect working order?
Unless an amplifier were receiving a modified sine wave or lower than necessary operating voltage- I cannot see where anything special is needed for power conditioning. A RFI filter might be a good idea if the circuit's being shared with lighting, motors etc...
Other than using the proper gauge power cord for whatever's being ran- do you have any suggestions?
Data distribution over anything but coax or fiber optics is odd and unnatural. I don't like phone line DSL. The power company's version probably isn't much more reliable. I have to use cable (coax)-based high speed Internet and that has worked flawlessly for years. We're too far away from the CO for DSL to work.
http://www.polkaudio.com/forums/showthread.php?t=71333http://www.polkaudio.com/forums/showthread.php?t=71382http://www.polkaudio.com/forums/showthread.php?t=71545http://www.polkaudio.com/forums/showthread.php?t=72539http://www.polkaudio.com/forums/showthread.php?t=75093http://www.polkaudio.com/forums/showthread.php?t=79010FYI, companies like SignalCable have a 30 day return policy. You could try a few different power cords from them to see if you can hear a difference between them and a captive cord or other aftermarket cords. I found that the change in sound varies from component to component. For example, I didn't hear any difference whatsoever when changing power cords on my Pass F5 clone, but changing cords on my Cambridge 840C was more than subtle. Enjoy!
I stand by what I said about internal filtering but believe good power cords can only reinforce things.
So after you buy that CAT preamp, whaddaya gonna do? Give it 3 years, and some vendors will realize power conditioning is best implemented in the component itself because the load conditions are specifically known.
