Budget DAC for my system, < 200$
rajacat
  • Washington State
Re: Budget DAC for my system, < 200$
« Reply #40 on: 20 Apr 2009, 03:29 pm »
The Valab Dac ($200) eliminates the op amps much like the vastly more expensive Red Wine dac and the Shigaraki DAC. I haven't heard any of these dacs but if you can remove a component from the signal path maybe you'll be closer to the music. :)
-Roy
raymondbeautrix
« Reply #41 on: 20 Apr 2009, 05:46 pm »
The latest affordableaudio magazine had a "budget dac shootout".  http://www.affordableaudio.org/aa2009-04.pdf
Their definition of "budget" was a bit over mine, but the winner was a 300$ musiland md10.  I'm not sure if anyone's sampled this one before.
whubbard
« Reply #42 on: 20 Apr 2009, 07:33 pm »
I've split our discussion of USB vs. SPDIF...
USB or SPDIF
-West
tortie
« Reply #43 on: 23 Apr 2009, 12:31 am »
I plan to try the battery supply and/or a better linear power supply.
 -Rob
FYI--the USB DAC you talk about above sound a lot better with a battery, try it soon.
Peace,
Lee
Hi lee.  What battery and charger do you use for the super pro 707?
doug s.
  • makin' music
« Reply #44 on: 26 Apr 2009, 03:53 pm »
here's your dac.  if you can diy, you can spend a few dollars more on it and have something that will holds its own against mega-dollar units.  amhik...   8)
http://www.audiogon.com/cgi-bin/cls.pl?dgtlconv&1245799901&/Art-DI/O-Dac-With-Extras
doug s.
mcgsxr
« Reply #45 on: 26 Apr 2009, 05:47 pm »
Agree with Doug on that ART DIO, I had a very modded one for a couple of years - I eventually sold it to go with a modded Logitech SB3, but I know that DAC did wonders in my system.
cryoparts
« Reply #46 on: 26 Apr 2009, 05:56 pm »
Any 12V SLA and a trickle charger.  PM me and I'll give you some links on where to buy.
Lee
 -Rob
Peace,
Lee
roscoeiii
« Reply #47 on: 26 Apr 2009, 06:28 pm »
I'd also take a look at the Beresford DACs. They like the Zero DAC, it accepts multiple digital inputs, selectable on the front of the DAC. The older 7510 can accept 2 Toslink and 2 Coax inputs. The newer 7520 has 1 Toslink, 1 USB and 2 Coax inputs. There is a fairly large DIY mod discussion group for this on The Art of Sound forums, where Stan, the designer of these DACs also frequently contributes.
Also has built-in headphone amp and volume control (should you want to forgo a preamp).
Lastly, MCM Electronics is also selling a rebadged version of the 7510, which can often be found for $79! Google "$79 DAC" to find the discussion thread that often includes the most recent coupon code to get you that $79 price.
Haven't tried other DACs, but really like the difference the MCM DAC made to the sound of CDs from my Oppo DVD player.  Since I will also be using optical output from my MacBook, the ability to easily select sources was crucial for me.
