0 Members and 1 Guest are viewing this topic. Read 16630 times.
Rashiki: that's a neat idea, I didn't notice that one on their site. I don't see any listing on ebay for that, at least now.Having the USB input only up to 16bit @ 48khz...does that affect the real-world soundquality for the listener at all? Or is it something slight and hardly discernible?
VALAB DAC, sold on EBay, $200 including shipping. Has a bit of a cult following on Head-Fi.org right now. Steve Nugent says that replacing some caps and add a low jitter transport like his Pace Car and it's world class.
24/96 over USB is tough right now. The two most common ways: Manufacturer licenses the CEntrance code (Bel Canto, Empirical, many others), which is a great solution, but expensive, so probably won't see this in inexpensive products any time soon. Write their own code (Wavelength, Ayre uses Wavelength's code, some pro stuff). There is another way, however, it is not released yet and I am under an NDA so I can't say a lot. Announcement will be made soon (before Can Jam). But, even this method may not filter down to the really inexpensive, entry level products.FYI--the USB DAC you talk about above sound a lot better with a battery, try it soon.
I'd like to find a good DAC in the $500 range that will also accept high-res USB input.
Rob: Audio Advisor has dropped the price of the PS audio DAC down to $695. Cheers Charlie
So I guess I'll ask my question in a different way. Why would any audiophile want or need more than 16bit/48khz? The only reason I can see is some sort of future-proofing.
West: It's no problem -- thanks for sticking with the thread and dealing with my slow decision-making process . So zero does 24/192 through usb? My only concern with the zero dac was Lee mentioned they have a slightly high fail rate/less reliable parts sometimes. It's possible they've improved since the upgrade.
