0 Members and 1 Guest are viewing this topic. Read 16174 times.
I should point out that having a headphone amp and a volume nob would be convenient for me, but my main goal is getting the best possible DAC for the money -- if that best dac is without these things, then I'm fine with that.
Does anyone have experience with multiple DACs I have listed here?
So...I suppose my real challenge certainly isn't lack of options, but a lack of means to narrow it down to one. Does anyone have experience with multiple DACs I have listed here? If I could start crossing ones off that are inferior to another, that would be a great help.I should point out that having a headphone amp and a volume nob would be convenient for me, but my main goal is getting the best possible DAC for the money -- if that best dac is without these things, then I'm fine with that.Thanks again for all the help guys.
Using XP now. I didn't realize that limited me. No work around? I just assumed since i have SPDIF out on my audigy 2, I could just use that.If it's really necessary, I could upgrade to vista if that made things more practical. So, I suppose the answer is: I can be flexible.
So asio drivers would be if I were to use a USB dac in windows xp, but I'd also have to use a supported audio player? That would mean that normal OS sounds or game/video sounds wouldn't work? I suppose I don't fully follow.
CryoParts also sells the Super Pro 707 DAC for around $120. http://www.cryo-parts.com/usb_dac.html Also available on ebay and from several other sources.I picked one up a while ago and I think it sounds pretty good, especially for the price. I wish the USB input supported high-res formats, but so few DACs support anything above 16 bits @ 48kHz.It comes with a cheap switching power supply as well as a cable to use a 12V battery. I plan to try the battery supply and/or a better linear power supply. -Rob
